Hard to Start
Old Jul 20, 2011 | 09:57 PM
kikidbird's Avatar
kikidbird
Default Hard to Start
My truck takes a while to start. I crank it and it seems like it is going to start so I pump the gas pedal and no start. I wait a while and still hard to start, I do not pump the gas pedal and then she starts and runs fine. I shut her down and try to start it and same thing, Hard to start. What is going on here?
Old Jul 20, 2011 | 11:09 PM
kikidbird's Avatar
kikidbird
I tried to start it and it almost seems like the timing is off.
Old Jul 20, 2011 | 11:19 PM
CPTAFW163's Avatar
CPTAFW163
pumping the gas pedal does nothing in a fuel injected engine. people did that for a carb engine because it primed the cylinders.
You check the fuel pressure?
Old Jul 22, 2011 | 12:18 AM
kikidbird's Avatar
kikidbird
CORRECTO MUNDO! You are correct, I checked the fuel pressure and zero pressure. I turned on the key and did not hear the fuel pump switch on. I checked the fuses and relays and it was the Fuel Pump relay. I replaced it and she runs fine. Thank you very much. I LOVE THIS FORUM!
