trailer harness
Old Jul 23, 2011 | 09:50 PM
Mill Man's Avatar
Mill Man
Default trailer harness
hey guys,
i have been looking high and low on here for some info on the fatory trailer harness. i have found some stuff but they were years other then 94-01. i was hoping someone could enlighten me a little and let me know if my truck is prewired.
it is a 99 Ram 1500 sport.
i was looking it over tonight and there is a wire and plug behind my rear roll pan. i am actually not so sure it is a sport model or had a factory roll pan at this point because every where i looked says something like the sport model with a roll pan doesnt have a prewire. so i checked my under hood fuse panel and there is a fuse and relay under there listed for the trailer. both the fuse and relay are in the correct place. as i said before there is a harness with connector at the back as well. i was not expecting to see this. i did check under the dash for the blue connector so i can hook up a brake controller as well. it is there. i hope this helps you guys to help me.
also i did contact chrysler about a build sheet. i am currently awaiting their responce.
thanks in advance
Jim
sorry just thought that was kinda "dumb funny."
Old Jul 23, 2011 | 10:20 PM
If your truck came with the factory tow package, the harness is factory. Since you have the connector for the brake controller, I am going to hazard a wild guess, and say, yeah, you probably do have it.
Old Jul 23, 2011 | 10:34 PM
Mill Man's Avatar
Mill Man
i kinda figured i did but i wanted to just be sure. i am trying to find a rear bumper for it to get rid of the roll pan and put a receiver on it. thanks for the info.
i just replaced the plenum gasket and i can feel its got a ton more power. i also just replaced the transfer case as well because it cracked and i didnt know it. so i ran all the fluid out and ran it dry, destroying the internals. i then found out that the rear U-joint was toast as well so i replaced that as well.. now i gotta pull the trans pan and try the OD sensor cleaning to fix the 2nd-3rd shifting problem.
Old Jul 23, 2011 | 10:49 PM
Good luck finding a rear bumper.... (at least, in the used market....) seems they really liked to rust out, and fall off on the 2nd gens. Mine is more a collection of brackets than anything resembling a bumper......
Old Jul 23, 2011 | 11:40 PM
Mill Man's Avatar
Mill Man
lmao, yeah everything i have seen or found used anyway have all rotted out like the old toyota pickup frames and beds from the 80's. i did however find an aftermarket one from autozone for around $150.
