rpm going up and down and stall ?????
Old Jul 24, 2011 | 04:24 AM
r0cxstar's Avatar
r0cxstar
Question rpm going up and down and stall ?????
i have a 1997 dodge ram 1500 sport.. 5.2 4wd
my rpms were fine and steady an about 1k. out of nowhere my truck started running really poorly and when i came to a stop sign the rpms were going up and down between 1000 and 500.. then drop to between 500 and 250 ..
and so on until it stutters and stalls..
i have replaced all 3 throttle body sensors ..
map
tps
and iacv
it seems more stedy now but it idles at 250-500 rpm
should i replace my catalytic converter or fuel pump/filter
should i check for vacuum leaks ? and if so how should i do that ? and what do i look for ?
what should i do ? please help
thanks
Old Jul 24, 2011 | 07:31 AM
neilsrpcustoms's Avatar
neilsrpcustoms
how does it run, other than idle?
It could very easily be a fouled plug or two, bad cap and rotor or plug wires.
If it feels hesitant while cruising but smooth under acceleration it could be a bad upstream O2.
Fill us in with a few more fine details........could be lots of different things
Old Jul 24, 2011 | 08:01 AM
knoxy's Avatar
knoxy
Same symptoms for me were due to a bad pre-cat O2 sensor. Replaced that and it cleared up.
