Output speed sensor issue-1998 RAM 1500
Old Aug 25, 2011 | 08:07 PM
kingnadda999's Avatar
kingnadda999
thanks I will check that next
Old Aug 27, 2011 | 03:16 PM
kingnadda999
What one is the speed sensor the one tail shaft or the one over the pan
Old Aug 27, 2011 | 03:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
VSS is in the tail shaft, the RWAL sensor is on top of the rear diff. What is the problem you are having ?
Old Sep 3, 2011 | 06:31 PM
kingnadda999
Default Any more ideas
Changed the o2 output speedsensor cat isnt clogged also changed plugs wires cap rotor the transmission doesnt slip and fluid looks healthy but when I got up steep hills of any kind just drops in power runs high rpms just gets gut less quick oh its 1998 5.2 and fuel pressure is fine when just sitting at idle
Old Sep 3, 2011 | 06:59 PM
zman17's Avatar
zman17
Well if the AC is changing vents, you have a vacuum leak.
Old Sep 3, 2011 | 11:13 PM
kingnadda999
Default it not the a/c changing the vents
It when going up hill at high speeds it looses all power the a/c vents close I am not ruling out a vacuum problem I just wondering anything that could cause it to loose power like that and causes the power loss to start
Old Sep 4, 2011 | 01:36 AM
gdstock's Avatar
gdstock
Previous owner already replace cat before I got my truck. Since it appears that all of these have or will have the plenum gasket blow, I decided to do the kegger mod before I have problems. Engine ran fine before (other than inability to shift into 3rd). Since cat was clogged, I am sure the plenum is blown.
So started on this project today. Thankfully, the various threads on this forum provide tons of helpful info. Thanks!
