ABS/brake light issue
Old Jul 24, 2011 | 06:06 PM
gillgetter's Avatar
gillgetter
Default ABS/brake light issue
I have a 2000 Ram 2500 4x4 V10 sport quad. Speedo doesnt work till 25mph, rear brakes touchy upto that speed. Im gueesing the sensor on rear is bad? any pics on how to replace it? is it hard to do? Iits a plow truck so alot of surface rust on that rear end so I'm hoping its not going to be a headache getting it out.
Old Jul 24, 2011 | 06:57 PM
They are generally fairly easy to swap out, and I wouldn't be surprised if that sensor was indeed the issue. If the PCM isn't getting reasonable speed readings, it will confuse the ABS as well..... thus, turning on the lite..... I am surprised you aren't getting a CEL as well.
Old Jul 24, 2011 | 09:54 PM
methpmp's Avatar
methpmp
Mine was easy 2 bolts and a screw driver to wiggle n wedge it out of the diff. I took the spare tire out for more room ..
Old Aug 5, 2011 | 01:39 AM
28-1 pfd's Avatar
28-1 pfd
Default ABS/brake light problem's
i have a 97 dodge ram 1500 larime club cab 4x4 auto 6ft 5.2 v8 magnum i just bought this truck back in june of this year i just found out that my abs/brake light has been out i have replaced the steel brake line's and the front two caliper's and the rear sensor i also found on before i replaced the calipers that there where no front abs sensors i was told that i have RWALS which is i think rear wheel abs system i did the disconnect the battery thing and still notthing except for the lights go out for about a 1nd to a minute then come right back on and i also checked to see if i had the abs modual and i dont see it in the bay of the truck is there a an abs module for this truck or no ? but idk what to do anymore any suggestion's n answer's ?
