Running rough
Old Jul 24, 2011 | 07:38 PM
kane912's Avatar
kane912
Default Running rough
Okay so i just replaced the Camshaft Position Sensor in my 01 Ram 1500, and now it is running worse then before. When i say running i mean not moving anywhere, when you put it drive or reverse it goes nowhere and in neutral you cant rev it up at all. it just stalls out. what are some fixes for this
Old Jul 24, 2011 | 09:44 PM
For a first check, remove the pre-cat O2 sensor from the exhaust, and see if the engine doesn't run any better.
Old Jul 24, 2011 | 10:26 PM
JSTMoto's Avatar
JSTMoto
Also, did you use a sensor from the dealership? Our trucks are sensitive to aftermarket sensors.
