Need desperate HELP!
Old Jul 26, 2011 | 02:09 PM
Bob1500's Avatar
Bob1500
i would check the ground probably not the problem but its were i start when i work on dodge knowing how bad they are. never seen copper wire rust till i worked on dodges they would be rather good if they bought better wire i love how easy they are to work on
Old Jul 26, 2011 | 02:26 PM
jmaki7121's Avatar
jmaki7121
Using the diagrams that Ramzy sent I was able to track the pins affected by the bare wire that I suspect is the culprit. Surprising enough the pins were 10, 14, and 25 and all three are for the Leak Detection Pump. So I am off the check. lol
Old Jul 26, 2011 | 03:21 PM
Which sensors have voltage on both sides?
Old Jul 26, 2011 | 08:39 PM
jmaki7121's Avatar
jmaki7121
Sensors that have voltage on both sides would be: Crank Position sensor, Throttle Position Sensor, Camshaft Position Sensor, Map Sensor. But, when I check the EVAP Leak Detection Pump I get nothing. So I check the wires for continuity from the plug in to the Leak Detection Pump and the appropriate pins on the PCM harness and they all check out, no issues. So that tells me that there is an issue within the pcm.
Old Jul 26, 2011 | 08:41 PM
jmaki7121's Avatar
jmaki7121
Bob1500 I check the ground first as that was the first and easiest thing to check. Got to check the easy stuff first. lol
Old Jul 26, 2011 | 09:06 PM
jmaki7121's Avatar
jmaki7121
Unless anyone else has anything to add or to check I am pretty sure I will be ordering a pcm. Don't think it could be anything else. Thanks all for all the insite and help.
Old Jul 26, 2011 | 10:27 PM
I tend to agree with you. Most of those wires are in the same connector, but, NOT right next to each other..... as a final test, unplug that connector from the PCM, and with the various sensors unplugged, check for continuity between the wires, and also the wires to ground. If they check out ok, I do believe you are correct. Time for a PCM. Is there a wrecking yard around that you could get one cheap from, just as a test??
Old Jul 26, 2011 | 11:38 PM
jmaki7121's Avatar
jmaki7121
I will do that prior to ordering, whats one more day and more testing. I want to be sure before I dump a couple hundred dollars. I did call the local salvage yard and used auto parts store and they checked the entire midwest and absolutely nothing out there. I may have to try calling a few others but i think I can send this one out to get repaired. Otherwise I'm looking at anywhere from $200-$800 for a re-manufactured pcm. Unless I can find a schematic and go through it myself.
Old Jul 27, 2011 | 10:51 AM
jmaki7121's Avatar
jmaki7121
So someone correct me if I am wrong, I do believe I should get some voltage to the Leak Detection Pump from the PCM on at least one of the three pins correct?
Old Jul 27, 2011 | 11:38 AM
Looks like there should be 12 volts on pin 2 of the connector. (dark blue wire)
