Lift kit help
Why does no one use Google any more, it took me 2 minutes to find this.
http://www.rockymountainsusp.com/dodge2wd.htm
someone was telling me a 4wd lift kit will work is that true? and thank you for the help everyone. i found this one site can you all tell me if its a good lift to you. http://app.infopia.com/Shop/Control/...112/rid/127794
Because after 2" or so you need upper control arms to fix alignment problems. Kits with control arms cost much more.
Trending Topics
I had a 97' 1500 2wd before i bought my 01's sport. I ran the Fabtech lift kit on the 2wd and it rode and handled great. The kit i used was new front knuckles/spidles and rear blocks with a new set of shocks. Definitely a nice kit. I also did not need upper control arms, alignment was easy and no problems. Fabtech told me that for the std cab/ sb if you run the springs you will have a rough ride. So i stayed away from them up front.
IF you can find a decent kit for less than a grand then you are doing pretty good, the kits that are cheap don't include all the parts you will need and by the time you buy those you are at or more than the price of the one I listed, in the end yous pent a grand on an inferior kit, then you trust your life and those around you to a crappy kit.
