Dana 60 rear diff
Old Jul 26, 2011 | 08:54 PM
1nordictom1's Avatar
1nordictom1
Default Dana 60 rear diff
is their someone on the site who has the hook up for differential rebuild kits? limited slip rebuild kits?
Mine is making grinding noises after it warms up & at slow speeds, in forward & reverse.
Thanks
Old Jul 26, 2011 | 10:28 PM
Randy's Ring and Pinion, and a few other vendors carry everything you will need. Is the pinion seal leaking? Is the fluid up to the correct level? Does it have the friction modifier additive in it??
Old Jul 26, 2011 | 11:27 PM
1nordictom1
No pinion seal leak, Oil level is correct, & LSD lube in the diff.
I looked at Randy's, just thought there might be the best friend deal on the forum.
Thanks,
NT
Old Jul 27, 2011 | 08:35 AM
1nordictom1
I should put this question with my last post........
Are you thinking it's something else??
Thanks
Old Jul 27, 2011 | 11:46 AM
Just makin' sure you don't spend money you don't need to.
The traclok diffs were notorious for tossing the clutch retaining clips though, and that could cause them to make some interesting noises. Since your seals aren't leaking, that probably implies that the bearings are good..... what you may want to do is, jack up the rear, drop the driveshaft, and turn things by hand. If there is a bad bearing in there, you can usually feel it. Things should turn nice and smooth.
Old Jul 27, 2011 | 09:32 PM
1nordictom1
Thanks for the info. I picked up through a search that the Limited slip unit has problems, but I didn't see anything about the clips. If I need to do the LS unit, I might as well put in new bearings & seals.........
Thanks
