Need some help
Old Jul 27, 2011 | 01:46 AM
Overstreet's Avatar
Overstreet
Default Need some help
1. Does anyone know where to get wire routing clips like the strap kind on the right in this photo
http://cgi.ebay.com/ebaymotors/54-Pc...#ht_2575wt_941
2. Anywhere that sells the clips that attach the fender wheel well liners
3. Also were to find new bolts that go from the exhaust manifolds to the y pipe
4. What size and length are the throttle body bolts.
5. I really reallly need pictures of engine compartments and where all the bolts go... i have a lot of bolts that are not marked. I would really appreciate it...
Thank you for the help
Old Jul 27, 2011 | 03:10 AM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Well it doesn't help that you didnt post ANYTHING about your vehicle in your tag or description. I will say however if you need bolts specs there is a thread that has all that info here if you look for it or here are 95 and 96 service manual
https://dodgeforum.com/forum/2nd-gen...-download.html
you can get 2001 manual at rm-indy.com
Old Jul 27, 2011 | 10:08 AM
Overstreet's Avatar
Overstreet
Dude Im sorry but figuring posting in the 2nd gen ram section I would think people could figure out what I was asking since these parts are probably used on all the 2nd gens not model specific but it's a 1500 4x4 5.9.
Old Jul 27, 2011 | 11:42 AM
Check local body shops. If they won't sell them to you directly, they can probably point you at someone that can.
Old Jul 27, 2011 | 05:01 PM
Bob1500's Avatar
Bob1500
I get manifold to y pipe bolts right from Lowes just get grade 8 and you should be fine 3/8x3" just got some 3 days ago they worked nice flat washer lock washer and hex nut all 4 bolts and nuts cost me 8 dollars i think thats about as cheap as it gets.
