Should front drive shaft be spinning when in 2H?
Old Jul 27, 2011 | 02:38 PM
talthyren's Avatar
talthyren
Default Should front drive shaft be spinning when in 2H?
Just noticed this the other day, I always assumed when in 2H the front drive shaft would not be spinning...thought maybe my 4x4 was stuck or something?
Old Jul 27, 2011 | 02:49 PM
Nope. Shouldn't be. Check and see if the CAD is completely disengaging....
Old Jul 27, 2011 | 02:54 PM
talthyren's Avatar
talthyren
sorry....CAD?
It doesent "feel" like the truck is in 4x4...I know when im in it..wheels dont spin when you floor it cause the power is going to all 4 wheels...handles different..etc....but I noticed the shaft is spinning, also the 4WD light is off.
Old Jul 27, 2011 | 02:59 PM
CAD = Central Axle Disconnect. On the passenger side of the front axle. Has a vacuum actuator, with two lines going to it.
Try this: Jack up the passenger front wheel of the truck. With the trans in park, T-case in 2-hi, try and spin the front driveshaft by hand. It should turn easily, and you shouldn't see anything else turning.
If the passenger front wheel turns, the cad isn't releasing completely.
If the shaft won't turn at all, something in the T-case is messed up.
Old Jul 27, 2011 | 03:05 PM
talthyren's Avatar
talthyren
will do.
Thankya.
Old Jul 27, 2011 | 08:50 PM
98ramowner's Avatar
98ramowner
a locker in the front diff would also spin the front drive shaft even in 2h aswell
Old Jul 27, 2011 | 10:06 PM
catota's Avatar
catota
I just climbed under mine and can rotate the front axle in 2 h, 01 ,1500
