Headlight problem
Old Jul 28, 2011 | 05:17 AM
97tn4x4's Avatar
97tn4x4
Default Headlight problem
So the other night I was running with my high beams on and all my lights just flickered off then right back on then off again, so I slowed down and turned to the low beams and it quit doing it( for now). Anybody got any ideas?
Old Jul 28, 2011 | 08:44 AM
97tn4x4's Avatar
97tn4x4
I noticed on my way home the high beams won't actually come on now. If you click it toward you they come on but if you let it go like you're supposed to they go right back off.
Old Jul 28, 2011 | 09:37 AM
tweav88's Avatar
tweav88
Just a thought, your turn signal switch might be going bad since you also control your high beam with that, if you cant find anything else wrong with it, and think its that, i have a brand new turn signal switch in the mopar box and ill sell it for 90 bucks, the dealer wants 130.
Old Jul 28, 2011 | 09:55 AM
Bob1500's Avatar
Bob1500
i would check the ground right by the battery by the driver side headlight its on the frame or the fender wall right below the battery if i remember right. cheap place to start but
tweav88 is probably right
Old Jul 28, 2011 | 05:50 PM
97tn4x4's Avatar
97tn4x4
I'm gonna mess with it tomorrow when I get off and see what's going on.
Old Jul 29, 2011 | 01:09 AM
jasonw's Avatar
jasonw
Site Moderator
Both the headlight and multi-function (turn signal) switches/levers are known to be iffy on these trucks, especially if "abused" (extra things tapped into the stock wiring, which is barely adequate, if that, for stock electricity demand). In your case, I'm betting signal switch.
No offense, but $90 is still a bit high for that. $45 is what my local salvage yard charges for "A" grade units (near perfect condition) and you can get a brand new unit off of eBay for about the same. I have one off of eBay installed, did it myself about four-ish years ago, not a single problem.
