Hollowing out converter
Old Aug 5, 2011 | 02:27 AM
15austin's Avatar
15austin
Default Hollowing out converter
Is there any harm in hollowin out the converter? I know some newer vehicles make run worse if you do. Would it give more power? I dont have smog test so thats a non issue. Would it help with gas milage? Ive use the serch for the past 2hrs and not found exact answer. I have read about fixing the check engine light. More noise wont matter.
Old Aug 5, 2011 | 07:46 AM
sk8erdude's Avatar
sk8erdude
hollowing out your cat gives you more flow, which in turn gives you more power and lets the engine breath easier, which gives you better gas mileage. how much better? dont no... probably not a whole lot, maybe a little. it wont harm your engine, but you may have to do the non fouler trick so your check engine light doesnt come on.
Old Aug 5, 2011 | 09:13 AM
aim4squirrels's Avatar
aim4squirrels
It's worse for the environment. Worse for the truck if you don't straight pipe it, IMO.
Old Aug 5, 2011 | 09:31 AM
whatman27's Avatar
whatman27
im running stock y-pipe, and st8 pipe, flowmaster. cheap design i slapped together till i saved up enough for the real exhaust. buut i personally like the truck with out cats. Sounds beefyier and it feels like it has a lil more get up an go.
How much power it get ??? no idea lol bt i think its worth it
