TV Cable question
Old Aug 8, 2011 | 02:26 PM
i mow grass's Avatar
i mow grass
Default TV Cable question
While I was topping off some fluids today I decided that I would check the TV cable while I was there. In the past few weeks I have noticed it is a bit delayed in shifting to OD and shifts kind of hard. So I took some pictures of it, it seemed to have a lot of slack in it compared to the throttle cable. So I am thinking I need to adjust/tighten it up, would yall agree from the pictures below?
Thanks
Uploaded with ImageShack.us
Old Aug 8, 2011 | 02:29 PM
zman17's Avatar
zman17
Retired Moderator - RIP
2nd page in this thread, https://dodgeforum.com/forum/2nd-gen...-in-trans.html
Old Aug 8, 2011 | 02:36 PM
TV cable comes in at the rear of the throttle body. That cable is for the cruise control.
i mow grass
Thanks for the quick reply zman, I actually had printed that out yesterday. The cable I have my finger on is the one that will be tighted/loosed correct or will it be the one behind the adjustment mechanism?
Old Aug 8, 2011 | 02:51 PM
zman17's Avatar
zman17
You have to remove the air intake for better access. Hey You is right about the cable in your pic, I was just posting info on your thread topic.
Old Aug 8, 2011 | 10:58 PM
MonteC's Avatar
MonteC
The tv cable has nothing to do with o/d.
Old Aug 9, 2011 | 09:12 AM
zman17's Avatar
zman17
How right you are.
However, this is from the 98 FSM.
DELAYED 3-4 UPSHIFT
(SLOW TO ENGAGE)
1. Fluid Level Low. 1. Add fluid and check for leaks.
2. Throttle Valve Cable Mis-adjusted. 2. Adjust throttle valve cable.
3. Overdrive Clutch Pack Worn/
Burnt.
3. Remove unit and rebuild clutch pack.
4. TPS Faulty. 4. Test with DRBT scan tool and replace as
necessary
5. Overdrive Clutch Bleed Orifice
Plugged.
5. Disassemble transmission and replace
orifice.
6. Overdrive Solenoid or Wiring
Shorted/Open.
6. Test solenoid and check wiring for
loose/corroded connections or shorts/
grounds. Replace solenoid if faulty and
repair wiring if necessary.
7. Overdrive Excess Clearance. 7. Remove unit. Measure end play and
select proper spacer.
8. O/D Check Valve Missing or
Stuck.
8. Check for presence of check valve.
Repair or replace as required.
Old Aug 9, 2011 | 09:30 PM
MonteC's Avatar
MonteC
Sometimes I think they put that crap in there just to take up space. lol.
