wont accelerate over 70
Old Aug 8, 2011 | 05:48 PM
Ramonator44's Avatar
Ramonator44
Default wont accelerate over 70
last night i wast on the highway and i got on it it would climb to 70 then wouldnt accelerate past 70... the rpms went close to redline like it usually does with the pedal to the floor but would stop instead of shifting...?
also i tried with overdrive off and overdrive on did same thing regardless.
Old Aug 8, 2011 | 05:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Clogged cat and blown plenum most likely. Do a search here on DF for both subjects.
Here is some help, https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Aug 8, 2011 | 06:08 PM
Ramonator44
what about a tps issue?
Old Aug 8, 2011 | 06:14 PM
zman17's Avatar
zman17
I doubt it. Check the plenum, TV cable, Gov sensor and solenoid , etc..... I'd check the plenum first and at least eliminate the most common problem first.
Old Aug 9, 2011 | 04:18 AM
Ramonator44
if i look in the exhaust manifold down on the bottom there is a layer of black oil or grease but its not puddled up in there or anything
Old Aug 9, 2011 | 08:03 AM
zman17's Avatar
zman17
You really should pull the TB and look around the corners of the manifold with a mirror .
Old Aug 9, 2011 | 01:05 PM
BamaRam97's Avatar
BamaRam97
Tighten your valve cover gasket bolts. I do mine every oil change.
Old Aug 9, 2011 | 01:11 PM
zman17's Avatar
zman17
I just noticed that the OP said "exhaust manifold". And that's obviously not right.
Old Aug 10, 2011 | 01:38 PM
jolynnie's Avatar
jolynnie
I have this exact same problem with my 94 Dodge, and the mpg went to 9. I had some mechanics tell me that it needed a new tranny, but the bottom gears are so smooth. It just won't go into overdrive. I already changed the TPS, and it seems to help the bottom gears be even smoother but no fix. I am not a mechanic, but is cleaning that plenum thing something I could even do?
Old Aug 10, 2011 | 01:58 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Does the truck in question have power windows?
