need help with a few cel codes
Old Aug 11, 2011 | 12:51 AM
Joey Buentello's Avatar
Joey Buentello
Default need help with a few cel codes
Check engine light read a code 32 (open or shorted condition detected in EGR solenoid ciurcuit. Possible air/fuel imbalance not detected during diagnosis.)
and code 24 (TPS voltage high or low test tps). what is the proper procedure to fix these problems. I know how to check the tps.
Old Aug 11, 2011 | 05:50 PM
Brent Jones's Avatar
Brent Jones
With the TPS first I would make sure you have correct voltage coming to it. It should be steady 5 volts. If it is not then you have to run down a wiring issue with the supply wires.
Old Aug 11, 2011 | 05:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The Haynes manual has the test procedure for the TPS and all the other sensors for that matter.
Old Aug 11, 2011 | 06:55 PM
Joey Buentello
I know the tps procedure, but I don't even have an egr valve.
