Hazard lights do not work but turn signals do
Old May 1, 2015 | 08:54 AM
Moparite's Avatar
Moparite
Open the drivers side door and look for a small pull out panal on the side of the dash. Pull that panal and there will be two flashes in it
Look on the diagram on the back of the door it will tell you witch flasher is witch.
Old May 1, 2015 | 05:06 PM
What year is your truck?
Old Apr 26, 2021 | 02:13 PM
Dulybop's Avatar
Dulybop
Originally Posted by travman247
i am having the exact same problem... my hazards do not work but my signal lights only work if the hazard lights switch is in the on position. i just bought this truck(non-certified) so due to the hazards light issue it would definitely not pass a safety... based on what you guys have posted i am guessing i am going to have to purchase a new hazard/turn signal switch
I’m having that exact same issue do you remember what the fix was for yours?
Old Apr 26, 2021 | 05:59 PM
It would help if we knew what you were driving.....
Old Apr 26, 2021 | 09:28 PM
Dulybop's Avatar
Dulybop
my apologies I jumped the gun there. It was a 96 ram 3500
Old Apr 27, 2021 | 07:11 AM
You have two flasher units in the junction block on the side of the dash. One is for the turn signals, the other is for the hazards. I *think* they are the same part number.... but, not 100% sure on that. They are cheap though. Parts store should have 'em on the shelf.
