4WAL ABS/Brake Light
Old Aug 11, 2011 | 04:18 PM
Vader's Avatar
Vader
Default 4WAL ABS/Brake Light
1998 Dodge Ram 1500 4x4 Ext Cab w/4WAL 5.2
ABS/Brake light are on
Here is what I have done......
Rear Diff speed sensor install (Battery disconnected during process)
Bled brake system
Checked fuse (ok)
Any other suggestions of what could be causing this?
Thank you
Old Aug 11, 2011 | 04:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the brake line next to the gas tank. It can have a pin hole that it pretty much unnoticeable.
Old Aug 11, 2011 | 04:29 PM
Vader's Avatar
Vader
Will check that out, thanks.
Old Aug 11, 2011 | 08:52 PM
VEETEN's Avatar
VEETEN
Since you have 4WAL check the front sensors with a meter.
900-1000 ohms give or take.
The plugs are mounted to the top of the wheel well under the hood
Old Aug 12, 2011 | 06:40 AM
Vader's Avatar
Vader
I am not to good when it comes to electric stuff.
Do I use my multimeter for this?
Old Aug 12, 2011 | 12:42 PM
Yep, on the ohms scale.
