oreilys checked my truck with a code reader
Old Aug 11, 2011 | 10:20 PM
Joey Buentello's Avatar
Joey Buentello
Default oreilys checked my truck with a code reader
and said It wasnt establishing a link, I said ok and jumped in my truck only to find out that the oreilys employee hadnt turned the key forward all the way. popped an evap system code p0441. please help me fix this bad boy.
Old Aug 12, 2011 | 10:26 AM
Agostage's Avatar
Agostage
Ah yes, the great p0441. Haven't had it on my truck but on other vehicles. I wouldn't worry right off the bat because it's likely minor. Start off by making sure your gas cap is tight, check for vacuum hose leaks. It helps to listen in the engine bay while running to detect any sucking sounds. Can also use a spray bottle to try and detect bubbles. Check the canister and lines for damage. Then finally check the solenoid. For the car I was working on it turned out to be the EVAP vent valve, but I'm not sure our trucks have that. Took me months to track it down. Good luck. Hopefully someone else will chime in.
http://www.obd-codes.com/p0441
Old Aug 12, 2011 | 03:23 PM
Joey Buentello
can the evap vent valve be replaced?
Old Aug 12, 2011 | 03:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Forget the valve, go out and look at the system, like Agostage has suggested.
Old Aug 12, 2011 | 03:37 PM
blackbeasst's Avatar
blackbeasst
that right there is why advance auto doesn't send employees out with the reader anymore. complete morons.
some lady sued them in small claims court (and won cause this is america after all) saying that they cleared the codes out and her car broke down.
now they just hand it to you and tell you to follow the prompts!
Old Aug 12, 2011 | 04:25 PM
Agostage's Avatar
Agostage
Well sure it can, but just because it was the problem on my car doesn't make it more likely it's the problem on your truck. That code covers a lot of components. You could have a cracked canister, a piece of charcoal jamming your solenoid, a broken purge valve, hose leak etc etc. Start simple and move on from there.
Old Aug 12, 2011 | 06:48 PM
Joey Buentello
I'm asking if it can be replaced for a reason, reason being I have a melted piece of hose end that looks to be a valve of some sort, and is attached to the canister. Easier said than done ( checking the system) with multiple disk herniations.
Old Aug 12, 2011 | 07:00 PM
zman17's Avatar
zman17
Well if you see something melted, then there is a problem. Take a pic and post it. I know back problems suck, but we can't see what the problem is with your truck. Besides, if I can do it with one leg, I'm sure you can. LOL
Old Aug 12, 2011 | 07:14 PM
dhvaughan's Avatar
dhvaughan
there you go, playing the "leg" card again. LOL. sorry man couldn't resist.
Old Aug 12, 2011 | 09:27 PM
Joey Buentello
Will do bro.
