Rear Block Lift
Old Aug 13, 2011 | 12:42 PM
Ugly1's Avatar
Ugly1
Originally Posted by dhvaughan
its probably safer than driving a ford explorer.
Lol! Point taken. Evidence of the Explorer design flaws is well documented and is widely available. I haven't seen any solid evidence of the stacked block highway carnage. If credible evidence exists I would want to know so I can start worrying about my lift blocks.
Old Aug 13, 2011 | 02:14 PM
sk8erdude's Avatar
sk8erdude
you can get away with stacking blocks. but if you have any amount of common sense you realize its not the best idea. the farther you get the axle from the leaf the more leverage you put on it. just like getting a breaker bar with a longer handle to remove a nut. and if you dont weld or get a single block the chances of the blocks moving because its not one piece is obviously higher...
NOT SAYING YOU SHOULDNT OR CANT DO IT!
Old Aug 14, 2011 | 12:23 AM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Do you know what size my stock blocks are? (2001 ram 5.9 4x4) and what size big block would i need or if i add a block what size you think would look good with my 2.5" levaling kit to even it out and make it look good?
Old Aug 14, 2011 | 10:11 AM
sk8erdude's Avatar
sk8erdude
your stock rear blocks are 3" tall. if your putting on a 2.5" leveling kit you could get a 4.5" or 5" or 5.5". depends on if you want your truck to sit lower in the front a little or level...
Old Aug 14, 2011 | 01:45 PM
DogeRamGuy1993
Okay, thanks, i think im going to go with a 4.5" rear block from topgun
Old Aug 14, 2011 | 02:03 PM
Do the blocks from them include the little arm for the bump stop?
Old Aug 17, 2011 | 07:30 PM
Kwdog75's Avatar
Kwdog75
Originally Posted by Carl2206
.......or they read it on a internet forum instantly turning into an expert. No real world hands on advice on the subject at hand or commenting on a product they themselves have never used. I have no real world experience with stacking blocks because its an automatic FAIL.
or YOU just spent way too much time on dodgeforum.com!
Old Aug 17, 2011 | 10:33 PM
sk8erdude's Avatar
sk8erdude
no they dont...
Old Aug 17, 2011 | 11:07 PM
InnerCityHillBilly's Avatar
InnerCityHillBilly
a add-a-leaf could also get you a couple inches of lift in the rear, but probably cost more than the blocks, ive always been told that blocks aint the best idea in the world but thats all hear say, hell do what you want cause its your truck and if they dont work they dont work
Old Aug 17, 2011 | 11:30 PM
The reason blocks 'ain't the best' is because they move the axle further from the spring. That gives it more leverage to bend the spring into a nice pretzel shape, and gives you things like wheel hop..... aal's won't do that trick.
