Hub Hell
Old Aug 12, 2011 | 08:49 PM
krs7272's Avatar
krs7272
I used an airhammer with a chisel shank. Put it between the hub and knuckle you'll prolly beat up some of the splash shield in the process. But it can still be used
Thats how I got mine out
Also sand the inner part with like 150 before installing new one makes it much easier to align
Old Aug 12, 2011 | 10:31 PM
Cinci99's Avatar
Cinci99
Default Hub shoulder - a little play
I just replaced my tonight, not too bad, big hammer and alot of luck. I do have a question though. When I put the new hub back on there was a small amount of play between the shoulder on the new hub and the hole where the hub shoulder fit into on the truck. Has anyone else notice any play between the two, I did purchase the hub from the dealer.
thanks
Old Aug 12, 2011 | 10:47 PM
Tra23's Avatar
Tra23
Check my post (2500 4x4 frpnt end replacement hell.) There's a limk to a youtube vid that shows a trick way to get them off. Wosh I had seen it before I started.
Old Aug 12, 2011 | 10:48 PM
Tra23's Avatar
Tra23
Check my post (2500 4x4 front end replacement hell.) There's a link to a youtube vid that shows a trick way to get them off. Wish I had seen it before I started.
Old Aug 13, 2011 | 03:11 AM
JSTMoto's Avatar
JSTMoto
VEETEN beat you to it! He must have seen your thread.
I knew that video would come in handy around here!
Sure beats the heck out of beating the heck out of the hub from behind...
-JT
Old Aug 13, 2011 | 07:01 AM
dhvaughan's Avatar
dhvaughan
thanks
as long as the bearing seated all the way into the knuckle cavity, you're ok, and having a little gap at the outer edge might be a plus to prevent it from seizing in. but if you're not seated into the knuckle, then that's not good.
Old Aug 13, 2011 | 09:08 AM
skydog's Avatar
skydog
Well,got the drivers side off. One more to go... I used a good quality cold chisel and a sledge to beat on the seam. It finally let go. Damn I'm sore. 120k on the truck.
Does it make sense to replace them, or the bearing at least?
Old Aug 13, 2011 | 09:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It does make sense to replace them. And they come as a unit, not just a bearing. Not cheap.
Old Aug 13, 2011 | 09:33 AM
skydog's Avatar
skydog
Anyone know where I can get the rubber seal that sits on the axle shaft near the U-Joint?
Old Aug 13, 2011 | 09:38 AM
zman17's Avatar
zman17
You talking about where the axle goes in the tube?
