Tranny and not the kind found in the city.
Old Aug 15, 2011 | 02:49 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
That pic is of the hose coming directly off the lower radiator correct?
Old Aug 15, 2011 | 03:31 PM
  #22
jrp267's Avatar
jrp267
Yep. So drilling it out seems to be the easiest solution.
Old Aug 15, 2011 | 03:40 PM
  #23
zman17's Avatar
zman17
Yep, that's what I did. I think I tried a small bit first and all it did was spin the ball. IIRC I went right to a 5/16's bit and the plastic ball and spring was gone. Just make sure you clean the hose out good, I used some carb cleaner , then blew it out right away with compressed air. Don't forget you'll need the tool to remove the line from the radiator.
Old Aug 15, 2011 | 05:08 PM
  #24
jrp267's Avatar
jrp267
Drilled the check valve out and used some electrical parts cleaner and then air. That was way easier and cleaner than doing it as in the sticky. Next to service the trans then on to the leaky rear pinion.
Old Aug 15, 2011 | 05:17 PM
  #25
zman17's Avatar
zman17
And free
Old Aug 15, 2011 | 06:54 PM
  #26
jrp267's Avatar
jrp267
Yes free is nice and you dont have to worry about the line slipping off the hose clamp and losing the trans fluid all over.
