Check Engine light if I...
Old Aug 30, 2011 | 06:31 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Kingsnap
Center Harbor, Moultonboro line.
Up there a way. Just outside Manchester myself.
Old Aug 30, 2011 | 09:17 PM
  #22
Um. You don't just pour it in, and start the engine.... you feed it in slowly thru a vacuum line while the engine is running.... (careful though, easy to stall the engine.)
I did mine out by my storage unit. No houses nearby..... major friggin' smoke screen. They didn't have mosquitoes for two weeks.
Old Aug 30, 2011 | 11:31 PM
  #23
shooterfpga's Avatar
shooterfpga
your original problem sounded like mine. when i changed my intake i didnt seal it good, causing air to get sucked in and the tick tick tick noise, that sounded like a lifter. check to make sure when you replaced your plenum you sealed it good.
