Old Aug 6, 2015, 01:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Halo Led projector lights melting. Help
Old Jan 27, 2012 | 11:40 AM
saviourbutt's Avatar
saviourbutt
did you fix your lights? I bought the same after market kit as you, maybe differnt bulbs H1 and 6000k for my Ram SS/T
and they are running Hot on hi beam and the hi beam is acting as it is a daytime running light constantly on also added the relay harness and nothing. whats the fix to get these working
Old Jan 27, 2012 | 02:59 PM
Augiedoggy's Avatar
Augiedoggy
they ALL are prewired for the 9007 sport harness from china.whether they are advertised that way or not.. we all had the same problem... you have to swap two of the wires around... blue and orangeI think but cant remember for sure... I have the ones hans has with actual separate high and low bulb not fake projector... there's about a thread a month on this so just keep looking and you will find the one with the directions...And dont forget to complain to where you bought them if they get enough complaints they may eventually fix it but they have been wired this way since at least 3 years ago when I bought mine...
BTW they are way brighter once you fix the wiring...
Old Jan 28, 2012 | 08:07 AM
GZakk's Avatar
GZakk
^Thank you for explaining it. I ended up complaining to the company and they let me keep the lights and gave me a full refund. By the time I got the grill on my truck the snow hit montana and I havn't gotten a chance to redo my harness or change bulbs around. I still havn't figured out if Im going to change the harness around or get new lights.
Good luck!
Old Jan 28, 2012 | 10:54 AM
Augiedoggy's Avatar
Augiedoggy
Cool...I left some feedback on the installation youtube videos It funny there were alot of complains from other having the same problem...
Old Jan 28, 2012 | 02:53 PM
Crackshot's Avatar
Crackshot
Hmmm. Seem like the stock ones work good nuff 4 me. If it works don't fix it I always say.
Old Jan 28, 2012 | 04:10 PM
saviourbutt
Default spyder projectors
thanks guys I did complain to ebay seller, they openly mentioned they had problems with the smoked spyder ones melting, yet they still sale them, leaving peoples lives at risk.
left me hanging, as they try to solve my problem due to the wiring issue. I am not going to ship them back I will bite the bullet on this, I cant with a clear conscious send them back to be sold to someone else and put there life at risk due to melt down.
in addition I emailed complaints on the spyder site. for these lights.
http://www.spyderauto.com/product.ph...DLIGHTS-CHROME
regarding same concerns.
I found a good link to a possible problem solve
Dodge Ram (Sport Headlights) Super Heavy Duty Conversion Harness w/4 relays 9004
sold at suvlights.com
hope this is the fix and helps others with there investment.
or is it still the crossed wire issue.
unfortunately there site is down for maintenance
Old Jan 28, 2012 | 04:12 PM
saviourbutt
Default 9004 harness
http://www.cumminsforum.com/forum/94...onversion.html
Old Jan 28, 2012 | 04:23 PM
saviourbutt
Smile sorry I'm new to this
thanks again
Old Jan 28, 2012 | 05:42 PM
Augiedoggy's Avatar
Augiedoggy
You could say that... but then unless your truck is completely stock your a hypocrite right?
seriously though... To each his own stock lights dont hold a candle to mine once I took the 5 minutes to swap the two wires... and I like the updated look.
Old Jan 28, 2012 | 05:54 PM
saviourbutt
when you swapped the 2 wires, (which ones)
do you meen from the stock dodge headlight plugs, or ? ballasts ?
in addition to that, did you still have to use 1 or 2 relay wiring harnesses.
or are they now just plug and play.
I'm still working on the issue.
I seen the post on utube.
COMMENTS:
FYI these are not wired correctly for the non sport rams and need to have two wires that have to be swapped to function correctly and reach full light output
fathergratwick
@fathergratwick Our lights will not fit Sport models.. but we do provide the harness for them
Specdtuninginfo
I'm waiting to hear back from them now with a guarantee the wiring harness will resolve the issues
