Old Aug 6, 2015, 01:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Halo Led projector lights melting. Help
Old Jan 28, 2012 | 06:27 PM
  #21
Augiedoggy's Avatar
Augiedoggy
Originally Posted by saviourbutt
when you swapped the 2 wires, (which ones)
do you meen from the stock dodge headlight plugs, or ? ballasts ?
in addition to that, did you still have to use 1 or 2 relay wiring harnesses.
or are they now just plug and play.
I'm still working on the issue.
I seen the post on utube.
COMMENTS:
FYI these are not wired correctly for the non sport rams and need to have two wires that have to be swapped to function correctly and reach full light output
fathergratwick
@fathergratwick Our lights will not fit Sport models.. but we do provide the harness for them
Specdtuninginfo
I'm waiting to hear back from them now with a guarantee the wiring harness will resolve the issues
yeah I'm fathergratwick (dont ask) I posted that..
from what I found the ground is switched with the high beam pin on the lights...switch these two around and everything should work correctly.
I actually found the diagram here from another member a few years ago telling me which ones to swap I searched to find it but the above was all I found...
sport rams have two plugs and use 9007 bulbs and another I believe.
If the weather clears up I try to pull one of mine and see what wires I swapped...
Old Jan 28, 2012 | 06:55 PM
  #22
saviourbutt's Avatar
saviourbutt
Exclamation spyder halos
thanks I will be seeing my mechanic tuesday.
thanks for your efforts, will keep this tread posted.
Old Jan 28, 2012 | 08:41 PM
  #23
redheadhunter21's Avatar
redheadhunter21
Here's some pics of my light harness this is what it looked like after I swapped the wires....I swapped it on the truck side of the harness because it was easier.
This is on a 1996 ram 1500, with sonar/spider projector headlights
This is truck side....purple, black, red
This is the headlight side.....blue, black, red
Matching colors go together and the purple and blue go together
Old Jan 31, 2012 | 07:20 PM
  #24
saviourbutt
Thumbs up Spyder Dodge 94-01 Chrome Projector with LEDs Headlights
Mine Are Finally Working. Both Hi-Beam And Low-Beam Independently.
The Issue With My Set, Was With The Low-Beam Wiring.
SWITCHED: The Positive And Negative On The Low-Beam,
And They Seem To Be Working Fine For Now.
No Relay Harness
No Load Resisters
No Anti-Flickering Capasitors
No HID Warning Canceller
After Market Parts Needed.
Thanks For Your Efforts.
o.O _\/,,
Peace ouT
Old Jan 31, 2012 | 07:34 PM
  #25
Augiedoggy's Avatar
Augiedoggy
No Relay Harness
No Load Resisters
o.O _\/,,
Peace ouT
good to hear... Of course you'll never get the distributor to admit to that... Too much liabitily after they have sold hundreds, or perhaps thousands that were wired incorrectly...
Old Jan 31, 2012 | 07:57 PM
  #26
saviourbutt
Yes, And Never Forget The Safety Inspecters That Approved These.
OEM approved
ISO certified manufacturers
100% D.O.T / S.A.E approved.
As Posted In The Details On The Spyder Website For THis Product.
http://www.spyderauto.com/product.ph...DLIGHTS-CHROME
