95 Ram smokes when I decelerate
Old Aug 24, 2011 | 09:18 AM
rmiller's Avatar
rmiller
Default 95 Ram smokes when I decelerate
Been a couple years since I've posted a question but i have an issue that maybe someone can help me with. I have a 95 ram 1500 4x4 5.2 with 193,000 miles. I recently gutted a clogged cat, removed and cleaned the TB and installed new plugs, wires, dist. cap and roter butten. The problem now is it smokes from the exhaust when I let off the accelerater going down hill or coming to a stop. It doesn't smoke when idling or cruising. If I shift to neutral going down hill it doesn't smoke.
My first thought is the piston rings are wearing out. But I'm also wondering if a blown plenum gasket could be the problem. It's never been replaced and the truck is using a lot of oil. I looked for oil pools when I had the TB off but it didn't look that bad. It was black but not wet looking. Any input would be greatly appreciated. Thanks.
Old Aug 24, 2011 | 10:01 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Look around inside the intake manifold with a lite and a small mirror. You need to see the sides and corners. Other than that, worn rings can do that. Get a compression test.
Old Aug 24, 2011 | 10:25 AM
Might be valve seals as well. Coasting is a high manifold vacuum occupation, so, if the seals are bad, it can suck oil right around the intake valve.
Old Aug 24, 2011 | 10:27 AM
zman17's Avatar
zman17
Does it smoke when you first start it after a day or so?
Old Aug 24, 2011 | 02:49 PM
rmiller's Avatar
rmiller
It doesn't smoke when I start it even after sitting for a day. I'll run a compression check next. I appreciate the input.
Old Aug 24, 2011 | 03:06 PM
More'n likely blown plenum then.
