2000 dodge ram 1500 hard brake lines
Old Aug 25, 2011 | 09:17 PM
00DoDge5.9's Avatar
00DoDge5.9
Default 2000 dodge ram 1500 hard brake lines
The hard brake lines from that go from the master cylinder to I don't know what its called to the abs sensor or something, the box mounted to the frame on the front drivers side have rusted out and sprung a leak i just want to know how big the lines are i need to buy and what fittings i need to get to do it myself, i cant afford to have it done professionally.
I have the pipe bender but that's it. What else will I need?
Old Aug 25, 2011 | 09:21 PM
Some flare nut wrenches make the job easier, but, aren't really required. If you have alternate transportation, just remove the bad lines, and take them to the parts store, and get a straight line, with the correct fittings, and length. Bend it up to fit nicely, and have someone help you bleed the brakes. Plug the holes coming out of the master cylinder, so it does empty itself.....
