99 ram stalling
Old Aug 28, 2011 | 02:42 PM
cwest65's Avatar
cwest65
Default 99 ram stalling
99 dodge ram 5.9 4x4
Alright well heres my problems whenever i start the truck it runs and idles great but after warming up it runs rough and stalls when looking at my scan gauge it only starts to run rough when the oxygen sensor go into closed loop the oxygen sensors have been replaced before and it still does the same thing. I unplugged the sensor and ow the truck drives fine. Could this be a plenum gasket problem?
Old Aug 28, 2011 | 02:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yup, and the cat is probably clogged.
Old Aug 28, 2011 | 02:50 PM
cwest65's Avatar
cwest65
Well i didnt take the sensor out of the cat i just unplugged it and the truck doesnt smoke but it loses about a quart every oil change.
Old Aug 28, 2011 | 02:53 PM
zman17's Avatar
zman17
Unplugging the connector does nothing, you have to unscrew it from the bung. Either way, sounds to me like you have a blown plenum gasket.
Old Aug 28, 2011 | 03:02 PM
cwest65's Avatar
cwest65
Alright well whenever you unglug the oxygen sensor the truck no longer uses the oxygen sensors for tuning it runs on a preset mixture.
Soo if the plenum is leaking does that mean raw air will get into my exhaust and cause the oxygen sensor to detect more oxygen and increase the fuel mixture causing it to die?
Old Aug 28, 2011 | 03:13 PM
zman17's Avatar
zman17
yes, but that doesn't help with diagnosing whether or not the cat is clogged.
Old Aug 28, 2011 | 03:41 PM
cwest65's Avatar
cwest65
well i guess ill try that later. Im guessing the symptoms are there. I cleaned the throttle body not to long ago and i saw a small pool of oil laying in the intake. And when i replaced spark plugs i also noticed that there were two plugs that were oily. Does this indicate i have a blown plenum like in the plenum thread.
Old Aug 28, 2011 | 06:21 PM
zman17's Avatar
zman17
Yea.......
