HELP with e-fan issue
Old Sep 4, 2011 | 10:48 AM
Pacmanloads's Avatar
Pacmanloads
What Brand of Fans do you have ? The wires should not be that small , 10ga is ideal.
Old Sep 4, 2011 | 10:53 AM
snakeman's Avatar
snakeman
2 Hayden fans
Old Sep 4, 2011 | 10:59 AM
Pacmanloads
2 Hayden fans
Sorry Buddy , guess I read that too fast , I thought just the controller was Hayden . 16 ga wire is way too small with the amount of current they draw . I find that strange . I have FF Dynamics fans and they came with 10 ga wire. They never get hot at all , wet and muddy a lot , but never hot .
Old Sep 4, 2011 | 01:58 PM
jasonw's Avatar
jasonw
Site Moderator
Haydens are usually lower RPM fans that don't put out as much CFM as FF Dynamics or Flex-a-Lite fans, but they are generally cheaper too.
What models are they (and/or how much CFM do they put out?)?
Old Sep 4, 2011 | 02:07 PM
snakeman's Avatar
snakeman
Not sure of model# I think CFMS are 2200 16" fans
I know they are cheaper (on a budget) but they should not get so damn hot.
Old Sep 4, 2011 | 03:15 PM
aim4squirrels's Avatar
aim4squirrels
Fans should come with wire that can handle the load, but if you can rewire them all the way up to the motor on the fan, go for it.
Be careful though, as some fans are wired with a specific type of wire made for high amp loads, it may appear thinner, but it's adequate. That type of wire is usually wrapped in a cloth weave type material.
Whatever you do, don't just snip the ends near the motor and wire thicker wire to a thinner wire. That will just introduce resistance to the circuit and cause more heat at the splice point.
Old Sep 21, 2011 | 10:00 AM
snakeman's Avatar
snakeman
well 2nd controller burned up! I got tired of effing with it and put the fan clutch back on.
Old Sep 21, 2011 | 10:09 AM
jasonw's Avatar
jasonw
Site Moderator
I didn't want to say much because I feared that I would make you mad, but Hayden fans aren't known for their quality. And I couldn't find a Hayden fan more powerful than 1600 CFMs or so.
Old Sep 21, 2011 | 06:02 PM
snakeman's Avatar
snakeman
that wouldn't make me mad. I don't own stock in the company lol!
