HELP with e-fan issue
Old Aug 28, 2011 | 04:06 PM
snakeman's Avatar
snakeman
Default HELP with e-fan issue
I need some ideas why my e-fan wiring would be getting so hot. Hayden fan and control module from Pep boys. Dual fan setup. It appears I have wired it correctly but the wiring is heating up way too hot! It sometimes causes controller to stick in on position even after engine is off. Any one have any ideas b4 I fork over bucks for mechanic?
Thnx
Old Aug 28, 2011 | 04:26 PM
BackwoodsRam's Avatar
BackwoodsRam
use a bigger wire, alot of kits for anything from fans to lights come with wire thats to small. the smaller wire heats up more for a given amperage then a bigger wire. so get a bigger wire setup and a better controller, yours probably cant handle the amperage that your fans are pulling
Old Aug 28, 2011 | 06:19 PM
aim4squirrels's Avatar
aim4squirrels
10 gauge minimum for feed and return using 2 fans. I run 12 gauge to each individual fan as well, for the initial startup spikes.
Old Aug 28, 2011 | 10:10 PM
SilverSS's Avatar
SilverSS
Also make sure you do the grounds too. The shorter and larger the wire the better.
Old Aug 28, 2011 | 10:40 PM
aim4squirrels
Sorry, should have specified, all wires to and from fans are 12 gauge.
Old Aug 29, 2011 | 12:21 AM
jasonw's Avatar
jasonw
Site Moderator
+1 for the wire gauges. 10 for the power source wire from the battery, 12 (or 10) for everything else.
Old Aug 31, 2011 | 08:13 PM
snakeman's Avatar
snakeman
thanks for the info. what about the leads for the ac and the ignition source(I hooked mine to the wiper motors)? These leads are very small(not sure of guage)
Old Aug 31, 2011 | 08:17 PM
Ugly1's Avatar
Ugly1
those leads don't need to be as big since they don't carry near the current. 16-18 AWG will usually be completely adequate for the control side wiring if it's only driving one or two relay coils.
Old Aug 31, 2011 | 09:36 PM
aim4squirrels
Those are trigger wires only, not feeding current to the controller. Small gauge acceptable for those.
Old Sep 4, 2011 | 10:23 AM
snakeman's Avatar
snakeman
thanks for all the input
OK yesterday I replaced + power lead to battery with 10ga and from controller to fuses w/ 10ga.
Fans are hotter than hell! I think they have 14-16ga lead wires. Should I rewire the fan with 10ga ?
