need help with rough runnin ram
Old Aug 29, 2011 | 03:56 PM
01PurpleHaze's Avatar
01PurpleHaze
Default need help with rough runnin ram
hav a 98 dodge 2500 with a 5.9L i jus replaced the engine with one from a 95 model. We hooked eveything up jus how it came factory and after we started it, it idles like crap and when you hit the throttle it kills out, any ideas on how to fix??
Old Aug 29, 2011 | 04:00 PM
BackwoodsRam's Avatar
BackwoodsRam
the new engine is obd1, and your truck is an obd2, the pcm is trying to read things that arent there and making adjustments, which are making your motor run like crap
Old Aug 29, 2011 | 04:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you swap the intake manifold? If not, you could not have hooked everything back up. If you did swap it, clean the TB and IAC and read this, https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Aug 29, 2011 | 04:06 PM
01PurpleHaze
any idea how to fix the obd2 to obd1 swap easily? or will i hafta get wiring for obd1 and install
Old Aug 29, 2011 | 04:08 PM
zman17's Avatar
zman17
All you have to do is swap the intake from your old motor. And read the link I provided.
Old Aug 29, 2011 | 04:12 PM
01PurpleHaze
i hav swapped intakes already
Old Aug 29, 2011 | 04:17 PM
zman17's Avatar
zman17
Then read the link. And try cleaning the TB and IAC. Also, did you remove the crank sensor and reinstall after the swap? It is easily damaged, and the wires can get pinched between motor and trans. But , I suspect a clogged cat. Unscrew the precat o2 and see if it runs any better.
Old Aug 29, 2011 | 04:22 PM
01PurpleHaze
crank sensor was reinstalled fine and ok ill try that thanks
