Solenoid Conversion to GM. Should I do it?
Old Sep 1, 2011 | 10:43 AM
cosmorphis's Avatar
cosmorphis
Okay, this might be a dumb question but, you think it's because I didn't put enough transmission fluid in? I put in 5 quarts, but when I tried driving it around today, I checked and it was slightly below the "OK" area. I am going to feel really dumb if that is the reason.
describe what your shavings look like? are they frictions? are they steel and stuck to the magnet? are they aluminum and not stuck to the magnet? and how much are we talking about, a thimble full or a hand full ? do you ever hear any unexpected noises, pops, grinds, clanks, clicks.
It is like sludge attached to the magnet. The magnet was fully covered in it, and it was recently cleaned less than a year ago. I don't think there were any shavings, like big pieces. I don't know what people consider shavings, like a pencil shaving size? No, there wasn't anything that big.
Old Sep 1, 2011 | 11:03 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd adjust the bands like AIM said. Clean the solenoid(or get the BW), replace filter, put ATF+4 in it (to the correct level) and go from there.
Old Sep 3, 2011 | 04:32 PM
cosmorphis's Avatar
cosmorphis
I think I am having a bigger issue. I dropped the pan, and the magnet was covered in that metallic sludge, and I had just dropped the pan two weeks ago. I think what is happening is, the solenoid is getting dirty really quick, and just clogging up and not working. What would cause this metallic sludge to accumulate so quickly?
Old Sep 3, 2011 | 04:38 PM
zman17's Avatar
zman17
It's most likely band and drum material. Did you tighten the bands then?
Old Sep 3, 2011 | 04:41 PM
cosmorphis's Avatar
cosmorphis
No I haven't tightened the bands. Was wondering if I still should or not.
Old Sep 3, 2011 | 04:54 PM
zman17's Avatar
zman17
I'll let MonteC or someone else answer that.
Old Sep 3, 2011 | 06:19 PM
MonteC's Avatar
MonteC
converter is going.
