bad wheel bearing or ball joint???
Old Sep 5, 2011 | 03:28 PM
94ram4x4911's Avatar
94ram4x4911
Default bad wheel bearing or ball joint???
I've been lurking around the forum for awhile now but have yet needed to post yet yet until now, I have a 1994 1500 regular cab long bed, 5.2 auto tranny 4 wheel drive, when I put my new wheels on back in April I noticed that I could slightly wiggle my wheel, when grabbing it in the 12 and 6 position, and that was back in april, the play has not gotten any worse since then and I cannot figure out if its the wheel bearing or ball joints. Any help would be greatly appriciated
Old Sep 5, 2011 | 03:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Well have someone ELSE shake the wheel (as you described) while YOU look at all the components.
Old Sep 5, 2011 | 03:59 PM
94ram4x4911
I'll give it a try when it quits raining, I've looked before but couldn't see movement, but wouldn't ya think it would get worse over time? It hasn't gotten anymore play in it at all and it makes no noises what so ever
Old Sep 5, 2011 | 04:02 PM
zman17's Avatar
zman17
I suspect a BJ. But with the tire in the way, it's hard to tell when doing it yourself. Get a friend or your girlfriend or wife to help with the BJ's.
Old Sep 5, 2011 | 04:05 PM
94ram4x4911
Haha that's a good one, that's what I suspected its the ball joint, cause if it was a wheel bearing it more than likely woulda let go by now or atleast gotten noisey and have a lot of play
Old Sep 5, 2011 | 04:09 PM
zman17's Avatar
zman17
All kidding aside, you need someone to help you check. Have one of them inside the truck and saw the steering wheel back and forth so you can check the rest of the components as well.
Old Sep 5, 2011 | 06:25 PM
JasonCNY's Avatar
JasonCNY
Mine had a bit of play in all directions. 12 and 6, and 3 and 9. It was the bearing. It is tightened right up, NO play. From your symptoms, I would say ball joint, but definately have someone help. A lot of times it is the severity of the wear.
Old Sep 5, 2011 | 07:23 PM
94ram4x4911
It can't be too bad yet cause you can barely feel it move with the tire on and of ya take it off it doesn't move at all
Old Sep 6, 2011 | 08:34 PM
chrisdodge96ram5.2's Avatar
chrisdodge96ram5.2
grab the wheel at 3 and 9 and have someone hold the steering wheel, u jiggle the wheel back and forth if it moves BJ, if not drive the truck down the road and turn hard to left or right witch ever side is doing it, if u hear growling WB.
Old Sep 6, 2011 | 10:01 PM
DamnDodgeRam's Avatar
DamnDodgeRam
Could be your tie rod. If your wheels or tires are bigger those kill your tie rods
