Question on prepping surfaces for new gaskets
Old Sep 10, 2011 | 08:39 PM
Skeezix's Avatar
Skeezix
Default Question on prepping surfaces for new gaskets
When prepping a surface for a new gasket, at what point is it considered "clean enough"? I'm midway through the plenum fix with my new Hughes plenum plate and I'm getting reading to re-install the intake manifold. I have the surfaces smooth to the touch but they are not 100% shiny, bare metal. There is some dis-coloration that remains. If you close your eyes and run your fingers over the prepped surfaces, you cannot feel any transition. Is this considered clean enough or should I keep cleaning? Also, I'd love to hear any recommendations for best methods for preparing surfaces for new gaskets.
Old Sep 10, 2011 | 08:54 PM
I use a whizz wheel on an air grinder....... (they are little abrasive pads, different colors for different metals...... clean things up fantastic, but, require the air tool... and air....) Then I hit 'em with brake, or carb cleaner. Surfaces are squeaky clean, you could eat off of them. (and then clean 'em again before assembly.)
Old Sep 10, 2011 | 10:44 PM
jswain's Avatar
jswain
Discoloration should be ok, as long as they're smooth like you say. I cleaned mine with a razor blade, then wiped the surface down with mineral spirits. I also could not get all the steel surfaces shiny, but its been about 20k miles since I did the plenum and haven't had problems.
Old Sep 10, 2011 | 11:57 PM
gdstock's Avatar
gdstock
I agree with jswain, dicoloration is not a problem. I razor bladed mine then polished with extra fine stone (more than necessary but I had time to kill).
Smooth flat surface is the critical part. From the factory, the casting uusally has mill marks that do not present a problem (I previously worked as an engineer at an aluminum foundry. We did intakes as well as other items).
Old Sep 11, 2011 | 11:30 PM
Joey Buentello's Avatar
Joey Buentello
I hit my intake manifold mounting surfaces with a wire brush wheel. made sure to put a aluminum foil tray in the lifter valley to keep crud out , then toss tray and all the crud that fell in it.
