Heater core replacement - please help
Old Sep 13, 2011 | 01:22 PM
RageGuy's Avatar
RageGuy
How much coolant can I expect to come out? I have a 15 uart catch pan....
Also, how much needs to go back in? SHould I flush the system with water before I install the new core?
Old Sep 13, 2011 | 04:38 PM
Wouldn't hurt to flush the entire system before you yank the old heater core. (sure, it may leak onto the floor, but, what's the point of putting in a new one, and then circulating all the crap in your engine thru it?)
15 quart should be adequate to the task. If you are careful, you will only lose a little bit. Just be ready to cap off the lines when you take em off the heater core.
Old Sep 13, 2011 | 04:58 PM
RageGuy's Avatar
RageGuy
Whats the proper way to flush the system without chemicals? I was reading in another topic about filling the rad with water after draining the system, run it for a few minutes with heater on max, then drain the water?
Old Sep 13, 2011 | 05:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Since you like working on your vehicle, you should download the 01 service manual, and get a Haynes manual. https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Sep 13, 2011 | 06:20 PM
Why wouldn't you use chemicals?
