[Request] Plan front axle and steering components
Old Sep 16, 2011 | 11:52 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Holy Crap, almost 400 bucks for a track bar????? What's it made of? Unobtainium? Adjustable? Self-installing?? I paid a bit more than a hundred for mine from advance auto, and it's lifetime warranty......
Yes it's adjustable and completely eliminates the stock joint. I didn't want to replace the same type of joint only to have to replace every year given that I will be hitting the trails with it. If I was strictly street driving, then the $140 Moog would have been just fine, which is mostly like what you are referring to.
C'mon HeyYou, I'm sure you knew about this with your grand knowledge. The typical replacements are all $380+ (i.e., solid steel).
Old Sep 16, 2011 | 11:56 AM
matt72991's Avatar
matt72991
no S***!!!!!! i got a MOOG track bar for 118 out the door from advanced. you have to have them price match to Rockauto for that price btw.
Old Sep 16, 2011 | 06:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I've got a Brand new Thuren 0" to 3" trac bar in the box for 300 plus shipping if it not too late.
Old Sep 17, 2011 | 03:03 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
^that is very kind of you. I did look at Thuren as one of the choices. However, the BD one was already shipped. Again, I'm really very appreciative and would have taken you up on it had I inquired better earlier.
I'm sure someone around here would be interested.
Old Sep 22, 2011 | 07:51 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Default Ball Joint and Drag Link @ Pitman Removal Tips?
I'm having a heck of a time getting these out. I have a BJ remover.
Lower BJ
Upper BJ
Anything particular about these? I have noticed a difference with other years that mine point down, while other point up.
Also a heck of a time getting the drag link end out of the pitman arm. Slammed it with 3lb sledge like the others, but it won't cry uncle. Pitman arm puller isn't grabbing very well. But I did just go get a piece plate steel to help with surface area.
Thanks for any input.
Old Sep 22, 2011 | 09:03 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
hmmm, ok. Well was doing the lower one wrong. Found the video (duh) that explained the direction to push it down as opposed to up.
For the upper one though I was doing it correctly. However, only the stud came out. The casing remains in the yoke. Am I up a creek here?
http://www.youtube.com/watch?v=bf77O...eature=related
Old Sep 22, 2011 | 10:24 PM
You can either press it out, or, use a bfh, and a drift (a punch with a flat point.) and drive it out. I usually belt 'em a couple times with the ball end of a ball peen hammer, just to get 'em started, then, they usually pop right out.
Old Sep 23, 2011 | 12:11 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Thanks. Ended up getting a great fit with a 1" socket. Easy Peasey.
Can't say the same for the lower one though. I have to get some borrowed muscle.
Old Sep 23, 2011 | 12:19 PM
CPTAFW163's Avatar
CPTAFW163
Thise ball oints look good. However the bushings are cracked and withered.
Does anyone sell a polyurethane bushing kit for our trucks?
Old Sep 23, 2011 | 01:13 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You think?
Seriously?
