4WD light blinking on a 2 wheel drive truck
Old Sep 14, 2011 | 01:34 PM
ehjr72's Avatar
ehjr72
Default 4WD light blinking on a 2 wheel drive truck
I have searched the forums to no avale. Yes, you read the above correctly. Have a 99 dodge, 5.9L. two wheel drive. When you come to a stop the 4WD light blinks. Take off and the light stops blinking. I am not sure where to even start for this one... I hope somebody else has had this happen and can help. IF this was answered somewhere else on the forum, point me there as i did not find it... I look forward to the responses... Thanks in advance to all...
Old Sep 14, 2011 | 02:23 PM
chadhager03's Avatar
chadhager03
Are you sure it's not 4wd? Is there a front driveshaft? Lol that's weird though
Old Sep 14, 2011 | 02:29 PM
That's bizarre..... On the passenger side, in front, there will probably be a connector tucked up into the frame somewhere, that would normally go to the 4x4 switch on the front axle. (if you had one....) It's probably grounding out somewhere. Have a look, see if you can find it.
