White vapor out tailpipe and dripping cat converter...
Old Sep 19, 2011 | 08:04 PM
Maybe just a little.
Old Sep 19, 2011 | 11:09 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Has anyone asked the obvious question?
Have you had to fill up your radiator or overflow tank very often?
Old Sep 19, 2011 | 11:36 PM
candymancan's Avatar
candymancan
Well I have but I have also done a lot of work to the cooling system.
2 months ago i replaced the timing cover gasket and 4 weeks ago i replaced the water pump, bled the system as best as i could and within 2 after doing that i noticed the water level dropped about 1 1/2 inchs from full to low. However i think that could have been because i didnt bleed all the air out and eventually it came out on its own.. Before i did all the work tho to this as far as the cooling system no the level never went down in the year i had it. 2 days ago tho the o ring on the bypass tube started to leak so i replaced that again and refilled the system. So i guess i just need to keep driving it and watch it..
Zman has a point tho i can be overly paranoid about my vehicle... its just that its the only thing i have to make money and i dont want it to break on me so i've fixing everything thats been going bad on it.
I have another issue with it where the front tires are wearing out on the outside quickly... so fast in fact in another 7k miles they will be gone... I had an alingment done fixed the 4WD, had all the joints checked and its still doing it. But thats another story..
