Burning oil
Old Jul 22, 2005 | 01:03 PM
DODGERAM99's Avatar
DODGERAM99
Default Burning oil
Hey Guys I got a problem!!!! I have a 96 ram 1500 with 106,000 miles. I recelntly come across this problem. I burn alot of oil and fouled out the 8 cyliner plug. when I pulleed the plug it was extremely cover in oily and crap. It does lack hourse power now. what is the problem
Old Jul 22, 2005 | 01:48 PM
V10's Avatar
V10
Default RE: Burning oil
Valve stem seal.
Old Jul 22, 2005 | 03:06 PM
greenmachine's Avatar
greenmachine
Bad ring or valve seal - take your pick
Old Jul 22, 2005 | 03:47 PM
steve05ram360's Avatar
steve05ram360
blown plenum gasket... look down the throttle body and see if you can see any oil pooling on the plenum (bottom of the intake) and use a flashlight and a mirror to check over by the #8 cylinder.
common problem, easy fix... https://dodgeforum.com/m_249261/tm.htm just time consuming...
