Here we go..Help
Old Sep 20, 2011 | 04:08 PM
NewbieDodge's Avatar
NewbieDodge
Exclamation Here we go..Help
Hello forum.. I just got my plenum gasket done after breaking three intake bolts and a pain of other problems. Now after I am all finished I find that the fuel line from the fuel rail that runs at the back side of the engine has a leak. I have been trying to find a part number or a line similar to the one I have. Any ideas would be awesome.. Thanks!
Old Sep 20, 2011 | 04:10 PM
tatitup8's Avatar
tatitup8
I did the same thing, went to a local Auto shop and told them what happen, and they just cut me some tubing, and it was only like 2$ take the tubing if you can to get the best size. Haven't had problems since.. ( 4 months ago )
Old Sep 20, 2011 | 04:18 PM
NewbieDodge
it looks like its a braided line.. and it looks like it needs the conector for the fuel rail.. i would think its a dealer part
Old Sep 20, 2011 | 04:23 PM
tatitup8's Avatar
tatitup8
Well, mine worked, just took off the butterfly clips from the old and put on the new, slid the new hose on, then put the butterfly clips on..
Old Sep 20, 2011 | 04:27 PM
redneck_ram's Avatar
redneck_ram
not to thread jack, but how did you go about taking care of your broken bolts? i broke one, and it has about 1/4" sticking up past the head. any ideas on how to tackle it?
Old Sep 20, 2011 | 04:32 PM
tatitup8's Avatar
tatitup8
Lots and LOTS of Pb buster, some vice grips, and a ton of motivation.. I had two. Broken bolts in the front, and one towards the back. It took me an hour and a half to get out, and that's taking turns with my friend..
Old Sep 20, 2011 | 04:34 PM
redneck_ram
i have the mopar penetrating oil, good stuff! maybe ill give it a try. only other option is a angle drill, and an easy out.
Old Sep 20, 2011 | 05:07 PM
NewbieDodge
I broke one in back on the pass side and the two front ones. They came out with vice grips pb blaster and some vibration.. hammer lol.
What did you use for the quick connect on the fuel rail side? My connector does not wanna come off the fuel rail.
Are you talking the crossover hose between the two rails?
I need the hose that goes from under the truck.. or the back of the block..cannot see where it is connected.. to the fuel rail.. it doesnt look like there is a return line.
Old Sep 20, 2011 | 05:24 PM
NewbieDodge
Lead off line seems to be the term being used on the net.. im not to sure on the technical name
Old Sep 20, 2011 | 05:59 PM
NewbieDodge
http://i178.photobucket.com/albums/w...1/PIC_0174.jpg
Name?
Place to buy one?
DIY?
HELP! lol
