Update: 2001 multiple misfires
Old Sep 20, 2011 | 05:59 PM
JasonCNY's Avatar
JasonCNY
Default Update: 2001 multiple misfires
Well, I made it back from VA., with one major issue. While filling the gas tank, it spilled gas all over the ground underneath my truck. I cleaned up the mess, and let it drain until it stopped leaking, and had no further problems. The truck ran great all the way down and back, loaded right up, including trailer. It did show codes for evap leak, and multiple random misfires throughout the trip.
I dropped my truck off at the dealer today, and told him he needs to figure out the problem, or I want my money back. He told me I will need to go to the attorney general for that, but said he will keep trying to fix the truck. He called me later, and said he was replacing the filler neck, sending unit, fuel pump, and also replacing the exhaust system.
I guess we will see how this turns out..?? I left this morning pretty ticked off, but if he keeps putting new parts on the truck, I can't really complain.
Old Sep 20, 2011 | 06:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You really should have just posted this in the original thread. But anyway, hope you get it fixed this time.
Old Sep 20, 2011 | 07:42 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Sep 20, 2011 | 08:27 PM
JasonCNY's Avatar
JasonCNY
Sorry, I actually thought about it, if I knew this was going to drag out , I would have kept one long post going...just in case someone has the same problem after sooo much trouble shooting. When all is said and done, I will list all the work done, and what actually fixed the random misfires. Thanks for the help.
Old Oct 17, 2011 | 06:24 PM
JasonCNY's Avatar
JasonCNY
Here is an update and a question...Up until last week, I have still been dealing with random misfires. While cleaning the fuel rail, the mechanic noticed a cracked pcv hose. Since being replaced, The truck has not misfired. It has only been a week, but it never even went close to that long before.
Is it possible such a simple thing could cause such consistant misfiring ?? The shop has been great about trying to fix the problem, but I'm afraid if it doesn't happen soon, but ISN"T fixed, they will tell me to take a hike next time I call...LOL Thanks for all the help
Old Oct 17, 2011 | 06:34 PM
merc225hp's Avatar
merc225hp
With them cleaning out the fuel rails did they also clean the injectors? and what did they find in the fuel rails ? When I changed out my injectors this past weekend I found all kinds of junk in them, A pluged or partial pluged injector will give a miss. I hope they found it for you.
Old Oct 17, 2011 | 06:43 PM
JasonCNY's Avatar
JasonCNY
They cleaned the injectors a few weeks ago. He said the fuel rail was not corroded or gunked up.
Old Oct 17, 2011 | 06:48 PM
zman17's Avatar
zman17
Did the new exhaust system include new o2's and a new cat?
Old Oct 17, 2011 | 07:08 PM
John D in CT's Avatar
John D in CT
I was all set to say "I doubt it", but then I googled "PCV misfire" and got all kinds of hits. Now that I think about it, it makes a lot of sense. That's just a big ol' vacuum leak. Seems to me it would fool the computer into delivering too little fuel, like when there's a leak downstream from a MAF sensor in vehicles that have them.
"An EGR valve that is stuck open at idle can have the same effect as a vacuum leak. So too can the wrong PCV valve (one that flows too much air for the application), or a loose PCV hose. The rough idle in these cases is caused by "lean misfire." The fuel mixture is too lean to ignite reliably so it often misfires and fails to ignite at all. Lean misfire will show up as elevated hydrocarbon (HC) readings in the exhaust, enough, in fact, to cause a vehicle to fail an emissions test".
http://www.aa1car.com/library/vacleak.htm
I have a strong feeling that was your problem.
"Did the new exhaust system include new o2's and a new cat?"
And did you put in a new crank sensor?
(Never mind; inside joke).
Old Oct 17, 2011 | 07:53 PM
zman17's Avatar
zman17
LOL, I know what I do first. I'm just afraid to say it now.
