P1285
Old Sep 21, 2011 | 09:37 AM
AFIN's Avatar
AFIN
Default P1285
So coming into work this morning my check engine light came on. Put the scanner on it and came up with P1285.
I did do a search to try and figure out what the code is. I came up with four different answers!
Accelerator pedal position sensor 3 circuit performance. Don't think this one is possible on a 2001.
Cylinder head overheat sensed
Fuel pump relay ctrl circuit
Fuel injection pump always on
So the question is which one is it for a 2001 1500 w a 5.2?
TIA
Tom
Old Sep 21, 2011 | 10:06 AM
jasonw's Avatar
jasonw
Site Moderator
According to the Trouble Code list we have on the forum:
P1285 Fuel Inj Pump Ctrller Always On
You are correct, I do not think we have an accelerator pedal position sensor. I believe that is a sensor for the newer HEMI engines.
The DTC list can be found here, in the FAQ section.
Old Sep 21, 2011 | 11:43 AM
AFIN's Avatar
AFIN
Thanks Jason,
I did see that one. When I did the search of the forums, it came up with a couple of different lists with the different explanations. I figured some of them were for different year model/vehicles. That's why I had to ask.
Definitely would rather troubleshoot wiring, vs trying to figure out why head is overheating.
