leak?
Old Sep 22, 2011 | 09:32 AM
camocody's Avatar
camocody
Question leak?
Im new to this but i have a 01 sport off road, and there is a leak coming from around the trans but its not transmission fluid because that's red and whats leaking in a little brown color. Any ideas what this could be? Thanks
Old Sep 22, 2011 | 09:35 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
One of two things could be happening here.
1. You need to replace your trans fluid.
2. All the dirt that has accumulated on your trans and t-case is being picked up by the fluid.
Make sure your t-case is full of fluid. When you pull the fill bolt out of the housing, it should be just to the bottom of the hole.
I think, however, you need to replace the seal between the trans. and t-case.
Mine needs to too.
Welcome to DF!
Old Sep 22, 2011 | 10:14 AM
CPTAFW163's Avatar
CPTAFW163
Your transfer case could be cracked. Happened to me. OR it could be the tailshaft seal from the transfer case.
I had the Transfer case replaced under warranty. If it is just a seal, then it will cost about 500 bucks.
Old Sep 22, 2011 | 10:35 AM
dodge dude94
^Technically, since he hasn't told us where he thinks it's leaking, we can't make that assumption, can we?
Most likely it is between the trans. and t-case.
Old Sep 22, 2011 | 11:27 AM
camocody's Avatar
camocody
I believe dodge dude94 is correct well this afternoon im going to check my t-case thanks for the help guys
