Truck wont run
Ok guys here is my problem. I have a 2000 Ram 1500 with the 5.9. I replaced the transfer case and i wanted to start the truck and let it run for a little bit. I hit the key and it fired right up. I let it run for about 3 minutes then i had something i needed to do so i shut it down. When i came back and I went to start the truck and it refuses to run unless my foot is on the gas. I can hold the throttle to keep the rpms right around 1,000 but if i let off the truck just shuts off..
Im at a loss of what it could be seeing as in how the truck ran perfectly fine 20 minutes earlier... Any ideas?
Disconnect the battery for a few minutes to reset the PCM, try again. If it still doesn't wanna idle, clean the throttle body/iac passages. If that don't help, test the TPS, if everything is good, replace IAC motor.
My guess is going to be the truck was just having a little bit of a "hissy" fit last night. After i finished the transfer case and speed sensor i got in and it fired right up with no problems. drives fine and everything
