Erratic Idle/Dies
Old Sep 23, 2011 | 02:26 PM
kikidbird's Avatar
kikidbird
Default Erratic Idle/Dies
I did an OH, now I have problem. It idles fine(800), then in 1 or 5 min the idle fluctuates then cuts off. I checked all my sensors and there fine. Any ides?
Old Sep 23, 2011 | 02:54 PM
Unplug the pre-cat O2 sensor, and see if it still does it.
Old Sep 23, 2011 | 07:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's suppose to idle somewhere around 650, not 800. What did the OH include? Plenum fix, new or gutted cat, new o2 sensors. Was the fuel sync reset? Was the crank sensor possibly damaged or the wire pinched?
Old Sep 23, 2011 | 09:16 PM
kikidbird's Avatar
kikidbird
Sorry, the idle is between 600-700. I replaced the crank sensor because I thought that was the problem. The OH is a short block with virgin parts and I installed a new plenum gasket. The cat is new. I don't understand about the fuel sync reset. I did replace the fuel line that connects to the fuel rail. How do I reset the fuel sync?
Old Sep 23, 2011 | 09:17 PM
kikidbird's Avatar
kikidbird
Default O2 sensors
If my O2 sensors are bad, wouldn't I get Trouble Code for the O2 sensors?
Old Sep 23, 2011 | 09:31 PM
zman17's Avatar
zman17
No, not always. And if you had the distributor out, the fuel sync needs to be set with a capable scanner. These links might help.
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
http://www.moparchat.com/forums/showthread.php?t=96310
Old Sep 23, 2011 | 11:15 PM
CPTAFW163's Avatar
CPTAFW163
Thanks for these!! Now installing a camshaft seems more like a task that a mere mortal like me can handle.
Old Sep 24, 2011 | 12:33 PM
kikidbird's Avatar
kikidbird
I ran my truck on the fwy early this morning to see if it just needed a break in at high rpm, but no dice. When I gun it there seems to be a grinding/clacking sound. I was thinking that maybe the noise is coming from my valves. I know that they are not loose because they would rattle. Would they make a noise if they are too tight?
Old Sep 24, 2011 | 02:30 PM
kikidbird's Avatar
kikidbird
I did it still does the same thing and the computer does not pick up the problem.
