keeps blowing the engine fuse
Old Sep 25, 2011 | 01:28 AM
countryboy94's Avatar
countryboy94
Default keeps blowing the engine fuse
i have a 94 dodge 1500 2wd with the 318 in it and when im driving it will blow the engine fuse and the abs and brake light is on all the time and sometimes the truck wont shut off when i turn off the key im completly lost i need help asap thank scott
Old Sep 25, 2011 | 01:32 AM
gdstock's Avatar
gdstock
Need a little more description. What do you mean by "engine fuse?"
Old Sep 25, 2011 | 01:35 AM
countryboy94
the fuse that is int the cab that is maked engine
Old Sep 25, 2011 | 08:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove the plastic covers from the steering column and check the wires inside. Other than that, you can download the 95 service manual from the FAQ section, and trace that circuit.
