ball joint help!!!!!!
Old Sep 25, 2011 | 04:34 PM
sam_priem's Avatar
sam_priem
Default ball joint help!!!!!!
i have to replace my upper and lower ball joints on my 96 ram 4x4. the top one pressed in fine but the bottom wont. i went to all the auto stores in my area and they all had the same thing. it doesnt press up far enough to get the snap ring on it. theres a little ridge on the bottom that doesnt go in the hole. my question is can i run the ball joint without having the snap ring in? would the weigh tof the truck keep it in place? i need to get it put back together tonight so i have to get an answer from somewhere soon.
Old Sep 25, 2011 | 05:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand and part # do you have?
Old Sep 27, 2011 | 07:06 PM
sam_priem's Avatar
sam_priem
i got it now. i found out that after market ball joints for a dodge dont use the snap ring. the upper ball joint keeps the steering knuckle in place so the lower ball joint just gets squished in between. i took it for a pretty abusive test and it held up fine.
Old Sep 27, 2011 | 07:14 PM
zman17's Avatar
zman17
Just be aware that you can get the ones with the snap rings, even aftermarket. Look up your vehicle on rock auto.
Old Sep 27, 2011 | 09:20 PM
sam_priem's Avatar
sam_priem
http://www.rockauto.com/catalog/moreinfo.php?pk=1546766
those look the same as the ones i put in. they came with the snap ring but the housing wont press far enough up to get the snap ring on. that ridge on the bottom of the housing is too large to fit in the hole, by about a 1/4 inch. i couldnt find one with a housing tall enough to see the groove for the snap ring. not to say they dont make one, just couldnt find one. next time i replace them (if i ever have to) ill do a little more research.
Old Sep 28, 2011 | 01:13 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I just replaced all four of mine. No snap rings for me. Used this vendor, quad4x4.com
http://quad4x4.com/Dodge1500Dana44fr...01.html#Joints
Kit comes with so much extra goodies. Totally recommend them.
