Old Aug 6, 2015, 11:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Door sagging/Not lining up with latch
Old Sep 29, 2011 | 10:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Arachnyd
I bought it from Rock Auto for $7 shipped.
The PROBLEM is that the hinge puns change in 1998... 98-01 is different, and those directions are for 98.
I found some directions online http://www.ehow.com/how_6540090_repl...inge-pins.html but I freaking WAILED on them and couldnt get them to budge.
I've done all the work myself, heck am I going to take it to a shop for this, but I think I may be getting to that point.
Can I use a saws-all and cut them in the middle and pop 'em out both sides? Or do I have to take the hinges off and take apart the doors? They don't have the springs that other people have referred to, and the new ones have clips.
When I install the new ones, do I do top clip up bottom clip down, or both clips down? I think I'm getting even MORE frustrated because it seems like such a stupid little easy thing that I feel stupid for having trouble doing this.
You are right, I used my 1/4" angled die grinder. PITA to get the old pins out.
Old Sep 30, 2011 | 11:13 AM
Arachnyd's Avatar
Arachnyd
I didnt want to use the grinder because then I'm going to strip the hinge paint, and then I'll be complaining about my hinges rusting out.
I'll use the saws-all in a few minutes.
New ones I was just going to throw some bearing grease between the hinge pins and the new bushings. Anyone have a different recommendation?
Thank you two for your thoughts, and i'll now appologize for acting like a little baby about this project.
Old Sep 30, 2011 | 12:11 PM
I just use the spray white lithium grease in a can. Good stuff.
Old Oct 2, 2011 | 11:20 PM
Arachnyd's Avatar
Arachnyd
This is kind of embarassing but... I failed.
You can see I tried to cut it with a saws-all. it went right through my blades. Hardened steel? I dont have a die grinder and my 4" grinder is too wide...
SO I opted to do it the ghetto way. I used washers. It works perfectly. My door closes right now and I dont get wind on the highway. ghetto, but as I said... it worked?
I also re-welded the cracked parts of the door:
And now the door works perfectly...
At some point I'll still have to fix the door, but I guess this works for now.
Old Oct 2, 2011 | 11:21 PM
What am I missing? Looks like it lines up rather nice?
Old Oct 2, 2011 | 11:41 PM
Arachnyd's Avatar
Arachnyd
It lines up perfectly with the washers in there.
its a failure because I couldnt get the pins out to replace them! haha...
Fixed the problem, but didnt fix it properly!
