96 Ram 1500 HELP!!!
Old Sep 26, 2011 | 05:35 PM
sarahmeiser07's Avatar
sarahmeiser07
Exclamation 96 Ram 1500 HELP!!!
I was driving my truck down I65 and I felt a pop so I crossed traffic to hit an off ramp and as I got to the top it died...I had to push it to the shoulder and it kinda started but died again....then it wouldnt start again. Had to tow it back home!! Changed the fuel pump...wasnt it...checked the fuses by the fire wall and switched them around...not it...changed the oil pressure sender/reciever...not it. It will run if we pour gas in the carb...so obviously its not getting gas...but not sure why...there arent any lights on. HELP...Im a girl and know a little about vehicles but Im no expert!!
Any suggestions would be apprciated!!
Old Sep 26, 2011 | 08:42 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. Check out the Ram sections,
FF
Old Sep 27, 2011 | 01:26 AM
jasonw's Avatar
jasonw
Site Moderator
I will move ya to the 2nd Gen Ram section.
Old Sep 27, 2011 | 07:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you try swapping relays around? Try swapping ASD relay with horn relay. If the horn still works asd relay is good. Swap the fuel pump relay with the horn relay too. Do you hear the fuel pump prime for a few seconds when you turn the key to on?
