vacuum leak?
Old Sep 26, 2011 | 08:40 AM
71dodge's Avatar
71dodge
Default vacuum leak?
after i put my tranny in i lost my radio so i can hear every little noise now. and when im driving there is this whislting from behind the fire wall. and when i give the truck gas the whistle gets louder. and i checked under my dash where i thought i heard it and i can hear it. but cant see it. its really anoying and causing the truck to idle a 700 rpm instead of its usual 600.. i really just need to find out what line it is so i can fix it.. i thinkit may be on the fire wall but im not sure were?
Old Sep 26, 2011 | 08:51 AM
chadhager03's Avatar
chadhager03
Do all of your a/c switches work? Does your 4wd work? (if you have that) does your cruise control work? Check all of those and it'll help you isolate the vacuum problem because those are all vacuum operated.
Old Sep 26, 2011 | 08:53 AM
71dodge's Avatar
71dodge
i have ac but when i step on it it goes away and then when i let back off the air comes back.4wd works and so does my cruise. but ive noticed that the crusie is almost less effective? like it takes awhile to work? maybe its just me im not sure. it works though all of it works what else would it be?
Old Sep 26, 2011 | 09:14 AM
CPTAFW163's Avatar
CPTAFW163
Search Wildvents on this forum.
It can also be that your airbox is not on the throttle body correctly. That will cause WHISTLING. If you have a 14x3 air cleaner, then you will always hear whistling.
Seems to me that you have a bad vacuum check valve. Wildvents search should help that.
Old Sep 26, 2011 | 09:16 AM
71dodge's Avatar
71dodge
i did have to remove my cold air to get to a sensor one day? think i didnt put it on right? and were would the check valve be located at? im hearing the whistling on the drivers side close to the fire wall?
Old Sep 26, 2011 | 09:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If you do a search for the Wildvents thread, there are pics in it.
Old Sep 26, 2011 | 12:07 PM
71dodge's Avatar
71dodge
thanks for the help guys il check into it
Old Sep 26, 2011 | 12:19 PM
zman17's Avatar
zman17
The thread you want is check valves for wild vents.
Old Sep 26, 2011 | 03:57 PM
71dodge's Avatar
71dodge
so it wasnt my check valves... remember how isaid i could hear everything now that the radio was gone... well my amps were still hooked up and my speakers were picking up engine noise.. now i have a vacuum leak because wheni pulled the check valve on the intake off a white vac line poped out somwere behind the motor? does anybody know were it goes i dont have a clue
Old Sep 26, 2011 | 04:08 PM
Might go to the transfer case, if you have a 4x4..... fill out your sig with your truck info.
